Autotap logging results after cam install Need Tuning?
Ive had my FMS F11 installed for a week and have done some tuning with my Predator and logging w/both Autotap and the Predator.I have my Ltrims around +0.78 at cruise and 0 at WOT.My 02's at WOT are around 900-920.Timing is 26-28 with no KR.My question is how much more can a custom tune gain over this?These numbers seem to be great considering only tuning with the Predator.I definatley need the P0300 Random Misfire code values raised or deleted because it is screwing with my ST3500 TC lock-up.I have my idle set too 850 and tried to raise it more to 950 to help with the Random Misfire but didnt help.
Thanks
Thanks
LS1Tech Administrator
Received 1,795 Likes
For PO300 raise the values in all the low/idle rpm ranges of the misfire tables. I tried just turning off the DTC and that wasn't enough to fix the lockup issues. I maxed out all the low rpm misfire tables (something like 32,XXX) and that took care of the problem.
