Bin File Help... Tuner Cats need a factory 98 camaro
I need a factory bin file for a 98 camaro to re flash into a ecu... i have a 98 corvette drive by wire ecu and need the camaro file to convert to drive by cable
i emailed you in .cal and .bin format of a 6 speed file. If you need it to be a auto lmk and ill read out a auto file in TC format. Check out www.monodax.com too in the file section
