Dash won't light up and car won't start?!?!
Old 12-27-2011, 04:04 PM
98Ws698's Avatar
Default Dash won't light up and car won't start?!?!
Drove the car to work this morning and all worked fine with out a problem. I go out to take it to lunch and when I put the key in to start up the car the dash stays completley dark and the car won't turn over, click or antyhing. All the interior lights/radio/head lights/alarm work perfectly fine without a problem. The car has a fresh battery. Checked all the fuses and relays I could find and still nothing. Termals are tight on the battery with new term screws. WTF gives?
Old 12-28-2011, 12:14 AM
salemetro's Avatar
I'm guessing that your ignition switch just died.....sounds like the ACC. circuit is working, but "key on" and "start" are not working.
Old 12-28-2011, 09:00 AM
98Ws698's Avatar
Well looks like some where along the way something in the car was shorting out, so some thought it would be a GOOD idea to wrap the fuse with copper wire and jam it back in to allow the car to start and not continously blow that fuse
Old 12-28-2011, 09:58 AM
wait4me's Avatar
sounds like a mess.
Old 12-29-2011, 05:05 PM
98Ws698's Avatar
Looks like I'll be replacing the entire wiring harness in the dash area
Old 12-29-2011, 06:33 PM
NemeSS's Avatar
What caused the short?
Old 01-24-2012, 04:59 PM
98Ws698's Avatar
After market alarm wiring. Guess it was shorting out or something causing the dash to stay dark. I had it installed about 5 years ago and it just now surfaced as a problem. Had the entire aftermarket system removed and problem was solved.
Quick Reply: Dash won't light up and car won't start?!?!
