Will bad O2 sensors cause a lean condition?
this makes sensor output drop and appear lean.
However at WOT this should have no effect,
unless the "false lean" results in positive trims
being applied, and then this would make rich.
The GMAF is the likeliest cause of lean running.
Fresh O2s can get by with less exhaust heat
but will likely get just as "soggy" in a little while.
not to get off the subject but,how do you like that predator?(for tuning purposes) and have you gotten any new tunes from them for your mods? did you need to get your slp maf tuned even with diablo programming?
