Speedo hookup without using transmission?
Old Jan 3, 2012 | 07:29 AM
pwrtrip75's Avatar
Default Speedo hookup without using transmission?
I have a JW glide, it has the ultra case and tail. There is no provision for a speedometer or anything. Is there a way to wire the front wheel speed sensor up to the speedo wire and get it to work? I have HP Tuners, if i can do this.... how do I calibrate this?
Thanks.
Old Jan 7, 2012 | 09:48 PM
koolrayz's Avatar
Thanks.
Just cut the wires to the trans VSS sensor and splice them into the wheel sensor. You cant get it to adjust perfectly but it will get you in the ballpark
