What does the PCM use when the throttle position sensor is unplugged?
When I unplug the TPS, it runs very good, like as it should. Reving w/ the pedal everything is nice and smooth *when TPS is unplugged*
So, what does the PCM fall back on when the TPS is unplugged?
I suspect something is messed up w/ the tuning in that area, with a table that utilizes the TPS sensor to run the engine
(I've replaced TPS sensor, and it is showing normal values using HP tuners scanner)
