sputtering in all gears in idle help
Old Jan 13, 2012 | 12:39 AM
jbro90's Avatar
Default sputtering in all gears in idle help
hi i have a 2001 camaro z28 automatic with 96XXX on it. i can do a cold start and warm start easy no problems. But in all gears park reverse neutral drive 1st gear whether the engine is cold or warm the car seems to sputter idle kinda and the rpms drop slightly when it dose but just when i sputter idles at that particular point. It dose this every time i am in the car. there is no real rhythm to it that i can tell and there are no trouble codes that come up. like it idles good just like it is suppose to for a couple of seconds and the starts to sputter idle. When i start to drive away it acts normal until i stop at a red light or are creeping in traffic and it starts to do it again. if i rev the car up it goes away until the rpms come back down to idle. i let my friend drive it a couple of weeks while i was a a trip and he said that he put 87 octain in it. so when i got the car back i went straight to the gas station and filled up on 93 and ran sea foam in the gas. and it kept doing it. then i ran 2 tanks of 93 each with a bottle of Lucas it it cause i thought that i might have gunk build up in my engine from the 87 gas. it has been several weeks now still using 93 like it calls for and it still dose it. I'm so confused i don't know what to do? please help any help at all would be greatly appreciated.
Old Jan 13, 2012 | 01:02 AM
LS1TA_956's Avatar
check fuel pressure am having the same symptoms on my car it sputters in drive turned out to be the fuel pump
Old Jan 13, 2012 | 07:29 AM
Old Geezer's Avatar
Ck fuel psi, scan it, and data log it, when this is happening.....
Old Jan 13, 2012 | 10:26 AM
jbro90's Avatar
how do i check the fuel pressure i dont really have any special tools
Old Jan 13, 2012 | 11:12 AM
wait4me's Avatar
A fuel pressure gauge can be bought for cheap. Go to a parts store and get one. That is probably going to be it. That or change your fuel filter as well.
Old Jan 14, 2012 | 12:00 AM
jbro90's Avatar
well ima change out the spark plugs wires and the fuel filter and see what happens let yall know
Old Jan 17, 2012 | 10:51 AM
jbro90's Avatar
well the spark plugs and the wires did the trick no more sputtering thanks guys for all your help
