Replaced both O2 sensors still getting P0131/0151
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
Doesn't matter. When you are at idle your car doesn't need a Lot of fuel pressure to run. When at WOT u need more fuel. You said the fuel trims are high right? Check them and see if when u step on the gas the trims go down. That's an indication of intake leak. PM if you need more help.
okay, got some results-rather bad though....at cruising speed its at ~41-43psi and when i romp on it from 2nd gear the pressure drops and at the top of 2nd gear going into 3rd its at 22-23psi 0_0 im not gonna be doing anymore WOT runs until this is fixed. glad nothing went boom yet.
so what could it be? any suggestions and advice?
TIA guys
edit-if its running lean up top i dont get loads of KR though? i didnt remove anything KR related in the ecm
TIA guys
will do. gonna change the fuel filter this weekend and check if the fuel pressure at idle changes at all. thanks
edit-FWIW, the fuel filter thats underneath the driver side near the rear wheel, i noticed theres one rubber line thats not connected to the fuel filter(fuel filter only has one inlet/outlet) thats coming from the fuel pump side. dunno if thats important or not to mention.
after screwing up with the lock ring on the racetronix fp i got another one. buttoned everything up and primed the fp 5-6 times. installed the fp pressure gauge and fired the car up and its at a happy 58-59psi at idle compared to 52psi. gotta retuned the maf as its currently rich cause i was messing with the fueling to find out what was wrong originally.
