0411 PCM pin 24 red connecter
I am in the process of swapping my 98 harness to the 99+ harness and i am almost done. I round a broken wire and have not found the other end. It is a blue wire and in the harness it splits off and one end is inthe PCM pin 24 red. The other is on the TPS and it has another wire that comes off of it in the middle. does anybody have a wiring schmatics that shows where the other wire goes to? I have a pinouts for a 2001 pcm but it says pin 24 is not used. TPS has 3 wires 5 volt ref, ground and signal wire. Any ideas?
