LS3 Crate engine won't idle
you drop the gas pedal or even if you release it slowly. You have to slowly
release the gas pedal over the course of about 5 minutes to get it to idle then
it idles good. Really hard to drive it dies out all the time. It will sometimes
backfire through the intake too when you first give it gas off idle.
is. Changed 02 sensors and still same problem. Fuel pressure is steady
at nearly 60PSI. I tried mocking up the intake simpler and that didn't help
either. I looked everywhere for leaks and can't find any vacuum leaks.
