Hitting limiter on 1-2 shift only?
Old Feb 6, 2012 | 01:21 PM
ragtopz28's Avatar
Default Hitting limiter on 1-2 shift only?
Ok, so my friend/tuner (after a 2.73 to 3.42 gear swap) calibrated the speedo and increased shift point to 6200 (w/HPtuners). Now it bumps the limiter 2-3 time before shifting into 2nd. What else needed to be changed? Thanks.
Old Feb 6, 2012 | 07:39 PM
transam19's Avatar
The wot tables have to match each other. Match the 94% n100% column and that should work.
Old Feb 8, 2012 | 07:52 AM
Chubbz155's Avatar
I belive it is the RPM vs. Gear table that needs to be adjusted. I had the same issue with my car.
Old Feb 8, 2012 | 11:34 AM
ZL1Killa's Avatar
either that or the Speed table associated with the transmission shifting. I believe it uses the speed sensor as feedback when to shift.
Old Feb 8, 2012 | 11:47 AM
Chubbz155's Avatar
Yea it might be that also!
Old Feb 10, 2012 | 10:35 AM
ragtopz28's Avatar
Thanks guys! Need to find someone local that can do this for me. Then I can go out for another PB attempt.
