Little help please
Old Feb 8, 2012 | 05:22 PM
95blackZ's Avatar
Default Little help please
Hey guys. My check engine light came on a couple weeks ago and I went to O'reilly's to check it. I hooked up the OBD II reader and for some reason it won't read but whenever it is plugged in the fuel pump will constantly pressurize. The reader won't tell me what the problem is besides saying it cannot connect with the car. The car has been tuned before I got it about a year ago.
Any ideas would be appreciated.
Thanks.
Old Feb 8, 2012 | 05:30 PM
edcmat-l1's Avatar
Thanks.
If it's the car in your sig, an OBD2 scanner won't work. It's an OBD2 connector, but the 95s still had OBD1 protocol. It says right on the underhood emissions sticker.
Old Feb 8, 2012 | 06:06 PM
2xLS1's Avatar
Hey Ed, you're a smart guy. Have you ever heard why GM did that on those cars? They didn't do that on all their 95 model vehicles.
Old Feb 8, 2012 | 07:12 PM
edcmat-l1's Avatar
GM and Ford both had OBD2 connectors in SOME of the 1995 models. I was working at a Caddy store at the time, but for the life of me I don't remember why, other than a head start on the tooling.
They had data streams that were somewhat of a hybrid OBD2. They were actually referred to as OBD 1.5. I forget the exact protocol though. Been a while LOL
Old Feb 13, 2012 | 07:29 PM
grazi's Avatar
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
You need this cable and a laptop with a program like Datamaster.
You were probably hearing the low speed fans kick on when you plugged in the OBD2 scanner. Thats what my 94 TA did.
Old Feb 13, 2012 | 09:06 PM
gmdoctor's Avatar
if its obd 1, try jumping A-B terminals on the aldl with the key on. should flash codes through the mil.
