6.0 lq 4 swap
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Can anyone tell me what sensors and systems can be deleted and what must be kept when doing a 6.0 LQ4 swap into a 71 c-10. I want to redo the factory harness to save dollars. Want to keep it a mass air system and I have been told that I can delete all but one 02 sensors. I have the 6.0 and 4L80E and harness/pcm from an 06 chevy express.
You need to keep the two front O2 sensors. All of the evap stuff can be removed. You will need to delete all evap codes from the tune and delete rear O2 codes. It would be best to get a copy of the GM engine wiring diagram to help out on the project.
Jeff
Jeff
