Which "ECM Type" do I use in WinALDL for 94 trans am auto?
Old 02-09-2012, 09:31 PM
Dickdeandestructo's Avatar
Default Which "ECM Type" do I use in WinALDL for 94 trans am auto?
Cant figure out which ECM numbers to select.
Old 02-10-2012, 07:22 AM
I cant find a direct answer on the net.
Old 02-10-2012, 10:03 AM
2xLS1's Avatar
I've never used that program but I don't see that vehicle as even being supported.
http://winaldl.joby.se/aldldata.htm
Why don't you just use TTS Datamaster?
Old 02-10-2012, 06:32 PM
It cost money and I am looking for a free scanning program for now.
Old 02-10-2012, 07:10 PM
2xLS1's Avatar
You can datalog with Datamaster 20 times before you have to pay anything. Another one that I have never used but hear about is freescan.
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
Look here for more.
http://www.aldlcable.com/sc/pages.asp?pageid=20
Old 02-11-2012, 08:25 PM
I have Datamasters from TTS now and I cant get it to work. I can get a link to the PCM. I have all the right settings, usb driver latency to 1mS latency and changes the software data settings from 190-205, point by point as per the manual. I have the Moates.net ALDU1 cable and box with the open and 10 ohm switch. I contacted them and I am waiting for a reply from them. Was hoping to run it by every on here and gain some insight.
Old 02-12-2012, 05:05 AM
MontecarloDrag's Avatar
You can use Freescan, it supports your car and it's 100% free.
However, Datamaster is worth more than it costs. Invaluable tool for tuning, worth every penny I paid for it.
Old 02-15-2012, 05:27 PM
I got Tuner Pro RT to work well , so datamaster should work now too. For every one else to reference , my latency is set to 15 mS.
Quick Reply: Which "ECM Type" do I use in WinALDL for 94 trans am auto?
