LT1 timing
Old Feb 15, 2012 | 09:38 PM
Dickdeandestructo's Avatar
Default LT1 timing
My timing is about 44 at WOT, about 20 at idle. Isn't over 40 a little excessive for a stock LT1 with just exhaust and intake done?
Old Feb 15, 2012 | 09:39 PM
Oh yeah, I im not having any knock, so things on that front are cool.
Old Feb 16, 2012 | 08:04 PM
Mike454SS's Avatar
I've never ever run more than 36 at WOT in an LT1...LOTS of LT1's.
LT1's do add spark with RPM that I still have never found the table to control...but I've never seen them add more than 2 degrees doing that.
20 at idle sounds reasonable for an LT1...but 44 at WOT is way too high.
Old Feb 16, 2012 | 09:46 PM
Every thing feels fine, engine is running very strong(its brand new) and consistent. seems like it wants to stay at 38-44 @ WOT , more to the 38 side, but does hit 42-44 quite often.
Could there be a margin of error for the software I am using to read it? The air has been very cool and wet lately, and I just started doing the diagnostics so that may be it, I may see lower timing when things dry up a bit here , which they surely will. Like I said before , I am not experiencing any engine knock so it may not be a bad thing. I will do some runs tomorrow and see if things stay the same.
Old Feb 18, 2012 | 10:40 AM
Anyone else have some thing to say on this? I can post some more variables if you tell me what I need.
Old Feb 19, 2012 | 08:40 AM
Mike454SS's Avatar
Maybe you're pulling vacuum at WOT and putting it somewhere else in the spark table? Post the tune and a datalog.
Old Feb 19, 2012 | 09:00 AM
edcmat-l1's Avatar
Yeah 44 is a bunch. Doesn't seem right to have that much and no knock.
Old Feb 19, 2012 | 05:11 PM
This is a stock tune. I am data logging with tuner pro RT and a moates.net cable. Diagnostics on the cable check out. I am going to do a run tonight to see if it is consistent, it was a lot warmer and drier than lately today.
Old Feb 20, 2012 | 12:50 PM
same thing, every thing is working fine though
Old Feb 21, 2012 | 06:14 AM
Mike454SS's Avatar
What's your MAP sensor reading at wide open throttle?
Old Feb 21, 2012 | 10:30 AM
I will check it out later today and do a full report.
Old Feb 21, 2012 | 07:20 PM
Mike454SS's Avatar
LT1's reference MAP and RPM for spark lookup...there are a couple MINOR correction tables based on coolant temp and air intake temp...so I'd say let me know what those all say.
If the thing is really hitting that much spark at full throttle...either there's something wrong with the computer, the car is pulling a ton of vacuum, or it's got a problem with a MAP sensor that makes it think it's pulling tons of vacuum.
I'd look at what the MAP says with key on engine off, at idle, at full throttle...I think your problem lies there. I believe a bone stock aluminum head LT1 tune will run 32 degrees peak at full throttle...34-36 would probably be peak power on almost any naturally aspirated LT1.
