is there a table for (cold) start-up that affects AFR?
Is it okay to adjust the OL fuel adder at all? I was thinking of a vac leak as I was trying to figure out why sometimes my IAC in both park and drive at idle it goes to zero. I played around with the TB adjuster screw and it somewhat helped. What are all of the vac lines on the ls1? I sprayed carb+choke cleaner all around the air pump and theres a thin plastic vac line that’s near the ecm on passenger side but the car didn’t hesitate to stall. If theres a leak on the air pump would that cause a vac leak and cause the IAC to drop to zero? IIRC the air pump hose that’s on the passenger side that goes to the rear from the front of the intake manifold is wrapped in some sort of black tape come to think of it?
Engine: Fuel: General: Afterstart Enrichment: Initial Adder vs. ECT
The best way to do this is to adjust the table up a few decimal points at your current ECT range until the fueling is inline on startup. Be sure to let your wideband come on for a few seconds to heat up before you crank the car so that the o2 sensor reports accurate readings. If you don't have it connected directly to the battery I've found that using an external separate battery to power the wideband so it stay's energized while cranking so that you get correct fuel readings.
currently have the Engine: Fuel: General: Afterstart Enrichment: Initial Adder vs. ECT
zeroed out as thats what is set at the factory starting at 111*f and up. i'll set it at 0.05 for now and see what the afr is. thanks
