help with bosch 160lb tuning at idle
Old Feb 28, 2012 | 02:47 AM
tt383lt1's Avatar
Default help with bosch 160lb tuning at idle
i just bought a set of bosch 160lb injectors, i was told they are hard to get to idle. what is the trick to get them to idle right. thanks
Old Feb 28, 2012 | 07:54 AM
RedHardSupra's Avatar
up the idle rpm to where you can keep it alive to tune VE (i hope you're not doing MAF, as you're way past MAF's limits with 160lb/hr injectors). then do desired airflow/running airflow tables, and idle spark. once it's all smooth, start lowering the idle RPM to where it's still smooth and you can control it it (aka doesn't stall)
