4L60e will not upshift at WOT
The tire size, and rear gears. All Needs to match the mph numbers in the wot tables. Also the command rpm wot shift needs to be reached as well. If it was ttuned to shift at 6500 and say 47mph with 3.73 gears and a 26" tire. And you change the gear or tire. All the values won't add up. In order for it to shift wot from 1-2 or 2-3 all areas need to be reached.
