Please look a my OBDWIZ log
Old Mar 13, 2012 | 06:20 PM
Blue2KTA's Avatar
Default Please look a my OBDWIZ log
I am having an idle problem when stopped at a light. It will idle ok for about 5-7 seconds then it gets jumpy. RPM's don't move around too much. I took the car out for a drive and recorded the log.
2000 A4 63k
Thanks
http://www.mediafire.com/?x5yra1q7zpb2w73
Old Mar 13, 2012 | 07:32 PM
sreve's Avatar
Check your purge valve mode 6 has it failing tests for a leak.
If @ idle it's a vacuum leak
Old Mar 13, 2012 | 08:24 PM
Blue2KTA's Avatar
Which one is it on mode 6 ? Is the purge valve on the drivers side, one side connected to the fuel line and the other going to the front of the intake ?
