spark cutting out
when revving the car in nuetral it revs perfectly clean and all, however i tried to do a crank relearn (case learn) through the scanner and your supposed to rev the car slowly to the fuel cutoff, so as i perform the procedure the car just completely cuts out at 4k rpm just like it does when im diving and then the car will do that everytime i rev it until i key it off and then back on, and the same thing happens again if i try to do a case learn..
at first i knew my ve table needed adjustment and i got it adjusted decently and it has no affect on the problem and my rev limiters are set to 6900...
only thing that i didnt swap over to this engine from my preious engine are my cam and crank sensor ( i left the originals in there) , so i figured maybe it had something to do with the crank sensor and swapped my original crank sensor in with no affect, i havent swapped the cam sensor cause i didnt feel like pulling the manifold yet and i wanted to see if i can see the issue with my scanner so i have a scan file with me just revving it without doing the case learn so it was revving clean and im not exactly sure what the numbers should look like in a good situation so if anyone can please help here it is
thanks for any help
