Slight surge under light throttle
The default config will work with it. I dont have my wide band hooked for this since I dont think its reading right.
Then from frame 2785 till the end you see 0 tps but my idle is at 950-1100 making the car cruise around the neighborhood.
I did subtract 3 degrees of timing throughout the whole light throttle area after I read too much timing can cause that surge affect. Taking the timing out did not do anything.
And thanks CTD, I will try pulling another 7 out in that range to see if it makes a difference. My mods/set up is in my sig. Will give It a try. Wanna get this tuned as close as I can before I hit the dyno. Then I can see how jacked if any, my wide band is.
very small amounts of change....not big #'s...
your cracker is active when you are cruising down the road and above the MPH value set to enable it.
with way too much it can cause the "self driving effect" briefly, but if you have it that high, then you are really doing something wrong to begin with..
(and I'm referring to Follower/cracker as they are labeled in HP Tuners... IIRC, they are labeled opposite in EFI Live...its not right or wrong, its just terminology...)
your Running Idle Airflow is your base # that all Idle is based on...
then the throttle cracker only works when your throttle is open, once you let off it decays to 0 almost immediately
the throttle follower does a similar thing except for it is to add to your Idle airflow for when you let off the throttle to bring the RPM's down smoother so that your pcm can catch idle properly and not "Dip" or "Stall" from not being able to keep up with the speed of the rpm decrease.
you can log RMP/MPH/TPS/RAF/STIT/STLT and the Throttle Follower/Cracker and you can see how the follower/cracker react and how fast they decay to understand that they do not cause idle push/self driving stuff to happen...
1. Flairs up to 1500 rpms for a few seconds then drops to 400 is then recovers to a good idle
2. Surge starts around frame 2150
3. Frame 2613 starts the 0 tps cruise effect. it starts to increase my speed making it idle around 1100ish and brings the speed from 12 upto 16mph. so not only is it a cruise but and actual increase at 0 throttle.
All in all this car runs good now. If I could figure these out it would run GREAT!
that would be why you get a cruise effect and possibly the flare up as well..
you need to lower the Running Idle Airflow table
the fact that the car see's knock retard at startup tells me that you need more timing pulled from the start-up flare table...
try just making it take away an additional 50% of spark
I cant open the tune file from a previous post...
It gives me a parsing error, I can only guess that maybe you are using the beta? and I am not right now due to some bugs that were driving me nuts.
also, your timing jumps around too much when you are getting your "cam buck"
smooth out the timing table and a lot of that will go away and then we can determine if its just a poor spark table or airflow or both
I am running BETA version.
1. tranny
2. Closed loop
Not sure yet.
1. tranny
2. Closed loop
Not sure yet.
something in your old tune is different... that difference is what causes the surge
airflow or fuel related or a combo of both...
