help idenify fbody computer
Old Mar 27, 2012 | 01:01 PM
Toxic-Evo's Avatar
Default help idenify fbody computer
i have 3 computers. just wondering if you guys can help with what years they are
serv. # are
12200411
12200411
09354896
HDW # are
09386530
09386530
16220610
there is also about 4 other numbers on them.
if there is a certain number you need let me know.
Old Mar 27, 2012 | 04:19 PM
salemetro's Avatar
serv. # are
12200411
12200411
09354896
HDW # are
09386530
09386530
16220610
If they came from an Fbody, then they are 99-02. The reason that I say "if", is that the "411" PCM came in s10's,trucks,vette's and fbodys. I'm not sure what the "09354896" designates, but you might try calling a dealer.
Old Mar 27, 2012 | 07:04 PM
sreve's Avatar
same as the 411
Old Mar 28, 2012 | 12:01 PM
Toxic-Evo's Avatar
is there a difference between the 98-02 computers??
Old Mar 28, 2012 | 04:59 PM
salemetro's Avatar
Actually, 99-02 are the same in the Fbodys....just the tuning is different. 98 is an undesirable year, and I believe is NOT a "411" pcm. 98 has less internal memory/tunable parameters. 99-02 is what you're looking for, generally-speaking.
Old Mar 28, 2012 | 06:57 PM
TomM's Avatar
All three of them could be 99-02 PCM's, the third one for sure....The 411 PCM came out in 01 to 02 on F-bodys, and started in 01 and up for trucks. It is more sought after because it has 512meg of ram, can be flashed to run several Operating systems for cars and trucks, and also multi bar map systems....
Look on the PCM's and see what colors are written on the side of the PCM, red and blue is usually F-body, red and green is usually truck, van, GTO etc.....
I think those dates are close, somebody correct me if I'm wrong...
T,
