HELP, LS2 not getting injector signal, starts on starting fluid though
I hope this is posted in the right section.
I am at the final stage of an LS2 swap that been a real journey, compared to others that I have seen or read about.
The problem I have at the moment is, The car will start only on starting fluid. the injectors are not receiving the needed signal from the ECU.
The ECU was tuned by http://tunedbyfrost.com/ he has told me many times he has disabled the vats. I have no way of entering into the ECU to look for myself. By the way Steve is great to work with.
I have fuel pressure at the fuel rails, near 60psi and the injectors have all been tested by applying voltage to the injector coils one at a time, each time the injector opens up and the fuel gauge drops pressure quickly, showing me that there is plenty of flow (this is done with the car off, with rail pressurized) All eight test out ok, none of them are sticking.
After testing each injector for flow, I attempted to start the car to burn off the fuel that I recently sprayed into the cylinders, the car starts, but quickly stalls due to the lack of fuel.
What would cause the ECU not to send the injector signal, but allows the coils to fire? I have change the crank sensor with having the same end result that I started with.
Thanks for any help that can be given.
Riggs
Riggs
The positive conductor (pink) is hot all the time when the key is on, it is not switched.
I went through some wiring and found the cam sensor (pink-black) sensor signal was swapped with the (brow-white)low reference. After switching these two wires, the car won't start on starting fluid any more. I had the harness rewired from Current performance, they must have switched the two leads, from the extension pigtail to the cam sensor they were correct, but switched at the harness pig tail. I need to make sure that the pins in the pigtail didn't allow the wire to be pushed out when I plugged the harness back together, I hope that's what I find. I guess I will check the crank sensor next to make sure that is correct.
Any help or direction is much appreciated, Thanks.
Riggs
