Runs perfect! Then dies?!
Old Mar 25, 2004 | 03:22 PM
Classic Style's Avatar
Default Runs perfect! Then dies?!
Hey everyone, I have a problem with my LS1 on an engine stand. The engine runs, but only for about 5 seconds. After that, it shuts off on its own. Its not a fuel pressure problem, its not spark, and its not air delivery.. so I'm wondering what could be causing it. Just to fill you in on my wiring situation, I will try to lay it out clearly, and maybe you can give me some expert input.
On magnus' wiring spreadsheet, I have all pink wires on the C-100,101, and 105 plugs running to the ignition switch that require "Hot in start and run". This includes the IGN/INJ banks 1 and 2, the PCM hot from ignition, and a few others.
C-10x orange wire that runs to the always hot on the ignition switch is hooked up. I have the Ground hooked up, and I have the fan1 and fuel pump relay hooked up. I believe that is all.
Like I said, the engine runs for a few seconds, revs pick up, and then shuts off on its own. otherwise it runs really smoothe. The engine is on a stand with no coolant in it (yet - that goes in tonight) and mid oil level. Also, the engine is hooked up to the 4L60E tranny, but I had to swap a manual's PCM for mine cause mine's crunched (could that cause this?) Any input is appreciated!
Thanks,
Randall Lowe
Old Mar 25, 2004 | 03:35 PM
96SCTA's Avatar
Well I had a simualr problem Car would run fine in open loop. As soon as it entered closed loop it would die. Turned out to be bad o2 sensors.
(THEY WERE BRAND NEW )
Old Mar 25, 2004 | 04:55 PM
See this doesn't even get to closed loop. It literraly runs for about 5 seconds.
Old Mar 25, 2004 | 05:49 PM
deezel's Avatar
Could the low coolant sensor signal be the problem? I know the PCM does a bunch of self-tests when it first starts up. Maybe if it thinks there is no coolant it shuts the engine down...???
Old Mar 25, 2004 | 11:04 PM
xjarayax's Avatar
VATS bypass?
Old Mar 26, 2004 | 12:25 AM
CamaroCain's Avatar
Originally Posted by xjarayax
VATS bypass?
What i was thinking, Have you done anything to disable the vehicle anti-theft system?? They will allow only a few seconds of run time and then shut down.
Clint
Old Mar 26, 2004 | 03:15 AM
I ordered a little VATS bypass system off ebay for 30 bucks. Hopefully that will fix it, it seems everyone is in agreeance, that its the VATS
Thanks for the help.
Old Mar 26, 2004 | 10:16 AM
slow's Avatar
agreed vats.
the coolant level sensor is not related to the computer, just a idiot light on the gauge.
The coolant temp sensor, is computer controled, but should be fine for running 30 seconds or so, before i would be concerned about heating issues.
Ryan
Old Mar 26, 2004 | 04:48 PM
deezel's Avatar
VATS was my second guess...
good luck
