Which wideband with HP Tuners pro
Old 04-26-2012 | 03:44 AM
99_Z_155's Avatar
I ordered an AEM UEGO today. The price was definitely right. I am not a computer tuner. I only need something that will be able to alert me if either my n20 solenoid or fuel solenoid have issues. I think pretty much any wideband can handle that task (except for my Autometer, it refuses to stay functioning).
Thanks for all the feedback though guys.
Old 04-26-2012 | 07:31 PM
My6speedZ's Avatar
Be better to have a fuel pressure safety switch. If your fuel solenoid gave out half way down the track chances are you wouldn't see it quick enough to prevent a lean out.
Old 04-27-2012 | 04:17 AM
99_Z_155's Avatar
In my experience, a FPSS is nothing but an intermittent pain in the ***... But thanks for the suggestion.
Old 04-28-2012 | 10:18 AM
speedfreak2685's Avatar
Thanks for the input! Looks like I will be ordering a NGK!
Old 04-28-2012 | 10:37 AM
Can I run the NGK all the time with a round gauge for my a pilar pod? It looks like all the ones I see come with a square box readout. Also, who is this best to order it from?
Old 04-28-2012 | 11:48 AM
My6speedZ's Avatar
Marylandspeed has them:
http://marylandspeed.com/ngk-powerde...01-p-3219.html
As does ColoradoSpeed:
http://www.coloradospeed.com/index.p...oducts_id=6575
Old 04-29-2012 | 03:13 AM
99_Z_155's Avatar
I would like to retract my sentiment about how crappy I thought the Autometer wideband was. It worked great til I had issues. I assumed the issues were bad sensors or EMI. Upon dis assembly and inspection, the harness had been scorched by my header primaries in the one place I couldnt see the wiring. If the harness was not damaged, I feel that the setup would work flawlessly. Either way, the new AEM has been installed and is working perfectly.
Old 04-29-2012 | 12:24 PM
My6speedZ's Avatar
The AEM sure is pretty though
sexy car BTW
Old 04-29-2012 | 09:45 PM
sexy car BTW
And cheap! But I have been the chap route before and hasnt worked out for me too well.
Old 04-30-2012 | 11:07 AM
matt_prof's Avatar
A lot of wideband controllers in the aftermarket are still using Bosch LSU 4.2 wideband sensors, which have been obsolete in the auto industry for a long time.
All professional tunners have switched to LSU 4.9 sensors; the new gen of Bosch WBO2.
LSU 4.9 has a lot of advantages than 4.2. One example: with a LSU 4.9, you do not need to do "free air calibrations", which is a flaw of the design of 4.2.
Old 04-30-2012 | 09:43 PM
watman02's Avatar
No free air calibrations says so on there site. I just bought one today.
http://www.aemelectronics.com/wideba...fuel-gauge-25/
Old 05-01-2012 | 01:13 AM
  #32
94zGreen's Avatar
Tricky to wire up is a ******* understatement, pardon my French..
Old 05-01-2012 | 10:17 PM
  #33
Which one is?
Old 05-01-2012 | 11:41 PM
  #34
94zGreen's Avatar
Innovate, I mean it just seems excessive, it angered me, I currently have it rigged to a stereo harness, not the best but it works.
Old 05-03-2012 | 12:25 PM
  #35
BetOnMyVette's Avatar
Glad I found this thread as I am purchasing a WB this week. Think I'll go ahead and pull the trigger in the NGK setup. Now to figure out where the hell to mount the thing with stock manifolds/cats removed on a C5.
Old 05-09-2012 | 04:57 AM
  #36
Phil'sC5vette's Avatar
I use the LM-1 because its great to move from car to car. The 3737 sensor suck at $75 bucks each and only least me 3 month at a time.
I bought the LM-2 just in case im in the middle of a tune and it craps out on me, but I never use it and should just sell it.
Ill just go to the NGK when the LM-1 dies.
Quick Reply: Which wideband with HP Tuners pro
