Running a Cam untuned in an Ls3.
How well does the Ls3 ECM do with a mild cam swap? I am wondering if the computer would learn a well enough to run well and be drivable with a mild cam change? Obviously the car would need to be tuned to optimize the the power gains. The question I have is would the car run at all untuned with the drive by wire throttle system.
The specs on the cam are 226/228 .580/.581 on a 114 LSA. The Ls1 would run untuned with a cam like that and pick up power. Of course I realize that was with a cable driven TB. I know there are tuners in the Tampa area I am trying to see if it is possible to do a cam swap and run the car a while because I am going to be doing this on a budget.
I just put a 235/240 duration 630 lift 113 Lsa cam in the other day. Car is a drive by wire c5 Corvette. Its a 6 speed. It will idle after first start up, an I will limp it over to the tuner tomorrow, but its not "drivable".
http://www.youtube.com/watch?v=NzUfv...e_gdata_player
SlammedC5,
That's a lot more cam than I'm going to run and a lot of cam period for a standard CI Ls1.
Not really the apples to apples comparison I want but thanks for the input.
LS1Tech Premium Sponsor
Brian you will definitely want to get it tuned. Even with a cam that small it will have terrible street manners being left untuned.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I am trying to do things on a budget because it's a $30k car. I am doing research and planning now so I can do things well without breaking the bank and I want to avoid being one of the people that throws a boat load of cash at the car and winds up with mediocraty.
Kyle It would get tuned I am just throwing Ideas around right now.
