Need a tune
Old May 5, 2012 | 09:07 PM
dirty94SS's Avatar
Default Need a tune
Ok i was using a scan tool and recorded some live data idk what im looking at do you see anything wrong note i swap a ls1 into a 94 impala. 2001 ls1 and trans 0411 pcm
http://youtu.be/Lmeiwovb4sM
Old May 5, 2012 | 09:52 PM
dirty94SS's Avatar
any kind of input
Old May 5, 2012 | 10:25 PM
JonCR96Z's Avatar
Fuel trim is way high. What all is done to it?
Old May 5, 2012 | 11:51 PM
dirty94SS's Avatar
nothing i got the vats and emission deleted thats all
Old May 6, 2012 | 12:51 AM
SMOKINV8's Avatar
You need your MAF tuned. Your intake ducting has changed from the donor car, and/or you have a larger MAF housing. Either one can cause issues. Your long term fuel trims are telling you that you need 20+% fuel added at idle to be at the ideal air to fuel ratio. You need that fuel to make torque, so you've left a lot of driveability power on the table right now, unless you've got an exhaust leak pre-O2's or a vacuum leak.
Old May 6, 2012 | 12:58 AM
Frans96SS's Avatar
Feel free to give us a call if you need a tune.
Old May 6, 2012 | 01:01 PM
BLK02WS6's Avatar
Looks like the data was recorded while you were sitting idling - running those LTFTs at idle is often an indicator of exhaust leaks - are you sure you don't have any? Would have to see a log of a drive to find out - not just sitting idling...
Old May 6, 2012 | 01:58 PM
dirty94SS's Avatar
no exhaust leaks
Old May 6, 2012 | 02:04 PM
dirty94SS's Avatar
started the car while at idle I can see alot of fuel or condensation coming out the exhast while at idle... I put the maf 2ft from the TB i know on F body they was infront of the TB that could be my problem..
