160 Thermostat
I've read that with a 160 thermostat the engine temp runs about 175, the stock stat is 180, and the engine runs about 195.
Before the needle was always half-on half-off the 210 line on the gauge, after I put in the 160 stat it was just off the gauge. I did put in an aftermarket gauge and it runs about 175 - 180.
'stat unless it's extremely cold out and there is a lot of base
bypass (thermostat never fully closed). Which is not the case
on the Hype-Tech 160 as far as I've seen on my vehicle. With
drilled holes you might get there in arctic conditions but that's
not a problem down here in the swamp. I have one 3/32 hole
drilled in mine just for luck & bubbles.
