98 knock sensors vs. new type
Old 05-18-2012, 09:32 PM
stangtrader's Avatar
Ok well just looked over my log.seems less sparatic now for sure.only pulled timing due to my own stupidity in non boost regions where I had way too much timing. Otherwise it is tons better and not pulling timing randomly
Old 05-18-2012, 10:15 PM
98Zheadsncam's Avatar
Cool, so this is with kr data from a 2000 and later tune? I really need that efi live cable!
Old 05-18-2012, 11:48 PM
Basically.I used ghe data from a 01 2500hd lq4 pickup since the knock sensors and my motor came out of one. Im possibly gonna log a tiny bit tonight to see if my timing changes fixed the issue so I know whether or not the data works
Old 05-19-2012, 09:09 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
I just pulled that tune out of holdencrazy to compare thresholds. Those thresholds in that LQ4 tune are significantly higher than even an 02 Fbody tune that has the spark reduced. I would suggest lowering them a bit and see if it makes a difference. You want the thresholds just below where you would actually see real knock if you were getting it.
Old 05-19-2012, 10:49 PM
Thanks for the tip. Still learning how this all works. Got everything down but the timing portion mystifys me
Quick Reply: 98 knock sensors vs. new type
