2bar map tuning question
Old Jun 2, 2012 | 07:45 PM
02LS1ram's Avatar
Default 2bar map tuning question
I'm about to switch over to a 2 bar tune and my question is am I able to swap out my currect 1 bar map too a 2bar map and still be able to drive my car to my tuner without having and issues. Now I don't plan on going into boost or anything. just want to make sure I won't have an issuses.
Old Jun 2, 2012 | 07:51 PM
BLK02WS6's Avatar
No, you will have to wait to install the new MAP sensor until the tuner can put the 2 Bar operating system in - there are MAP scalers that have to be changed for it to even run with the new MAP sensor...
Old Jun 2, 2012 | 09:10 PM
02LS1ram's Avatar
That was answer I was looking for thank you
Old Jun 12, 2012 | 02:45 PM
white01ss's Avatar
You can actually install it but leave it unplugged. The car will throw a MAP sensor failure code. As long as the car has a properly working MAF the car will run fine off it.
As said, once you plug in the new 2 bar MAP it will need to be tuned.
Old Jun 13, 2012 | 07:43 PM
99VetteFRC's Avatar
What if I install the 2 bar MAP and the 2 bar OS at the same time. Will the car run and drive till I get it to the tuner? Is there anyone on this forum that could help out with a base tune just to make the car run till its tuned.
Old Jun 13, 2012 | 07:57 PM
BLK02WS6's Avatar
Yes, you can do that... Which tuning software do you have?
Old Jun 14, 2012 | 04:38 AM
99VetteFRC's Avatar
I have HPTuners. And will be installing 2 t70's and 80# injectors next week. Running 8psi.
Old Jun 14, 2012 | 05:20 AM
BLK02WS6's Avatar
I have HPTuners.
Can't help you... hopefully someone else can.
