42lb Racetronix SMP injectors- Need injector tuning data please!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have spent the last 3 hours searching the web for this!!!
I just finished putting my engine back together and plan to put the new combo in the car tomorrow. I really want to set the injector tables correctly so it will start and not run pig rich. I saw all sorts of bad stuff on lack of data on racetronics injectors. I can't believe that nobody has the right info or I am just not looking in the right place.... Is Racetronix not providing the data? Since they are flow matched and they go into how they are flowed, I would assume it is readily available???
I plan to call Racetronix tomorrow and see what they will provide since I just purchased a matched set of them. Old combo was a cam only Lq9 with svo 30# and ported ls6 intake. New combo is bigger cam, TEA ported trickflow 225 heads and Racetronix 42# on a FAST 92 intake.
Any help would be appreciated.
thanks.
I looked at the injectors this morning. I found the following numbers:
0892
0872
01D030B
I am assuming the last number is the part number?
the data from when I purchased them is:
Static Flow Rate: 42.29 lb/hr @ 43.5PSI
-Static Flow Rate: 48.83 lb/hr @ 58.0PSI
-Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
-Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Item Code: 01D030x
Weight: 91.00GM
Brands: Racetronix_
Manufacturers : Standard Motor Products
Stock: No
Model: 621031
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: FJ-SM-12S
Static Flow lb/hr (n-Heptane): 42.29
Static Flow Tolerance +/-%: 4%
Dynamic Flow (mg/pulse): 9.96
Dynamic Flow Tolerance +/-%: 6%
Coil Resistance Ohms: 15.9
Coil Resistance Tolerance +/- Ohms: .35
Spray Pattern: Tri-Cone
Connector Type: Minitimer (Bosch EV1)
O-ring Type: Viton
E85 Compatible: Yes
Methanol Compatible: Yes
Thanks!
thanks.
0892
0872
01D030B
Item Code: 01D030x
Weight: 91.00GM
Brands: Racetronix_
Stock: No
Model: 621031
O-ring Type: Viton
E85 Compatible: Yes
Thanks!
LS1TECH Sponsor
thanks.
Thanks!
thanks.
Thanks!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Advanced injector data is available on our support forum to confirmed / registered customers. With this data customers should be able to extrapolate the data required for specific vehicle platforms and tuning software. At this time we do not supply injector data pre-formatted for specific tuning software / platforms.
Guess I have to look in the right places.
I'm on the Racetronix forum now and was ablet to find the detailed data on the injectors. Now I just need to figure out how to translate that data to the tables in HP tuners..... I knew the data had to be avaialbe.
thanks.
thanks.
