P0300 Code of Death.
Old Jun 18, 2012 | 06:57 PM
iroczracer07's Avatar
Lol, that thread continued on for a bit. I thought all LS1's had a somewhat noisy valve train. If I heard wrong, by all means correct me.
Old Sep 22, 2020 | 09:28 PM
Jamie Robbins's Avatar
Originally Posted by Troy5061
Anyone ever get a p0300 random missfire code, cylinders 2,4,6,8 on the passenger side are all misfiring but the drivers side bank is fine. Running out of ideas, has new ac plugs, new ac wires, new fuel filter, checked fuel pressure and its good, new injectors and fuel rail, got a used computer and got it reflashed and nothing, has good compression. So I was thinking the right side cat plugged but it appears to be working on the scan tool and with a temp reader gun. Its missing so bad it sounds like its knocking, any ideas??? The vehicle is a 2002 1500 with a 5.3.
I'm having a problem with #7 and #8 misfire. I came across some information regarding your problem. Follow the ground for that wiring. It goes to the block.. if it doesn't look too good take it of and clean the ground
Old Sep 23, 2020 | 11:40 AM
Darth_V8r's Avatar
Moderator
Moving here
