F.a.s.t. Engine Management Help
Old Mar 31, 2004 | 10:22 PM
Z28 10 SECOND CLUB's Avatar
Default F.a.s.t. Engine Management Help
hey every one i was told to get a fast stand alone engine management system but im not sure exactly what it does if you guys can give me some info about it that would be great. the reason i was told to get it is because i just purchased a 427 ci stroker motor in a C5R block.
Old Apr 1, 2004 | 07:25 AM
Reckless's Avatar
Super Moderator
Depends on what you plans are ultimately. You can run a 427 motor just fine with a stock computer. The block has nothing to do with it.
Old Apr 1, 2004 | 07:50 AM
NoGo's Avatar
You don't need fast, you just need to find a competant tuner.
FWIW, we were running 8.90's with a C5R block and the STOCK computer.
Old Apr 1, 2004 | 08:37 AM
mikey's Avatar
LS1TECH Sponsor
Running 9's here with the stock PCM... You don't need a FAST.
Old Apr 1, 2004 | 11:48 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yah you don't NEED an aftermarket engine managment system to run a big inch motor but in the long run a system might uncover a little more power. But a standalone can run $2500-3000 so it's not cheap. I have a FAST bank/bank setup and it's necessary for a high hp blower setup.
