View Poll Results: Tuning for shifting into 4th gear @ WOT
Voters: 7. You may not vote on this poll
Tuner question: Do you allow 4l60's to shift into 4th @ WOT?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I am curious if you PCM tuners on here allow automatic 4l60e cars to be allowed to shift into 4th gear (OD) under WOT. High speed.... Said car has a semi-built up transmission.
Thank you for your input.
My answer was NO! I broke Two 4l60's that way.. 'the first time it happened, I really thought it couldnt happen again,, Till it did!!!... Now iam packing the invincible this baby takes all my rear butmount can throw at it in overdrive !!
I think I tuned one car that faced this possibility (A4 + 4.10 gear). I allowed the WOT shift to happen to 4th - but I added in a bunch of torque management to try and protect the trans. Never had an issue come back from that car's owner.
It depends on the build of the car and trans as well as the inteded reason for doing sutch. But I always warn everyone this symple fact, there is no bullet proof 4L60 trans out there. The 4L60 is just one week peice. It will brake, the question is when. If the car is over 600hp I advise my customers to look into the 4L80 swap if they want an OD trans.
