shift points with power programmer???
Old Jul 31, 2012 | 09:13 PM
stangkiller2005's Avatar
Default shift points with power programmer???
has any used the hypertech programmer to adjust shiftpoints on their automatic ls1?
i noticed u can change the mph for shift 1-2 and 3-4, and also raise the rev limiter. came with the car.
Old Aug 3, 2012 | 03:30 PM
Hypertech's Avatar
If you want to make a change on your shift points you can change the 1-2 (+3) 2-3 (+5) 3-4 (+8)
then move the rev all the way up
Old Aug 3, 2012 | 03:44 PM
Cool ima do that when I get home. Dosnt it have the option to set it like all the way to 6800? Seems to high? If you recomend it ill try it tho.
