Bad O2 sensor?
Old Apr 5, 2004 | 11:00 AM
koniu77's Avatar
Question Bad O2 sensor?
can a bad O2 sensor cause my car to run real rich and make it die at idle?
Old Apr 5, 2004 | 12:07 PM
NoGo's Avatar
Yes it can.
A good tell tale of this is starting your car after it has been sitting for a day. If the car runs fine for the first minute or so, then all of sudden starts running like garbage, it is most likley a bad O2 sensor.
Old Apr 5, 2004 | 12:36 PM
koniu77's Avatar
i also get a flashing ses light and a misfire code
Old Apr 5, 2004 | 01:56 PM
NoGo's Avatar
Oooooh.
What was the last thing that was done to the car before it started doing this?
Old Apr 5, 2004 | 02:17 PM
koniu77's Avatar
cam, heads, longtubes, and a 3000stall Vig verter
Old Apr 5, 2004 | 02:46 PM
NoGo's Avatar
What size cam did you install?
Old Apr 5, 2004 | 03:33 PM
koniu77's Avatar
222/226 .566/.569
Old Apr 5, 2004 | 06:22 PM
NoGo's Avatar
If the car appears to be running okay, just rich with a misfire code, then everything may be okay.
Headers (especially LT's) goof up the O2 readings and will cause the car to run rich.
The lope of the cam goofs up misfire detection of the PCM (makes the reluctor wheel speed inconsistant at low RPM) and sets off the misfire detection. Both of these problems are fixed through tuning.
This is all assuming that the car runs fine though.
If it is just your new mods, you should be able to get on the gas and the car should run fine when around 2500 rpm. If the car is still breaking up and misfiring at this high of an RPM, then you have other problems.
Old Apr 5, 2004 | 07:05 PM
koniu77's Avatar
besides idle problem the car runs fine.
ill probly tune my car by the end of this week, is there anyway i could manually increase my idle to about 900rpms so that i could drive the car for couple days?
Old Apr 6, 2004 | 12:09 PM
NoGo's Avatar
You can invert the screw on the stop on your throttle blade stop and use that to adjust how far open the plate will open up. This will increase you idle.
