KR with E85
Old Sep 11, 2012 | 04:15 PM
joecar's Avatar
The KR waveform isn't sawtooth shaped... so it might not be detonation... it might be a single instance of some mechanical noise;
if you have a Chassis Ear you can clamp/tie it to the engine block and listen to see if it is knock or mechanical;
try going richer and check that wideband and HO2Sx1 voltages both respond accordingly (I was expecting to see HO2Sx1 voltages above 920mV).
Old Sep 11, 2012 | 04:17 PM
joecar's Avatar
BTW: if you want VET to show values, enter your engine displacement in cc's (Edit->Log File Info->Vehicle, and then save the log file).
Old Sep 11, 2012 | 04:44 PM
salemetro's Avatar
Originally Posted by gpr
BTW, how do you setup a car to cruise at a leaner a/f mixture? Instead of setting it up to cruise at 14.7 or lambda of 1, how would i make it leaner to try and get a little better fuel mileage?
AFAIK, the only way to do that, is to run OL and tune it where ya want it. Not what I'd ever want to do, as you'll lose fuel trims....besides, E85 (to me) means that you're pretty-much throwing "MPG" out the window.
Old Sep 11, 2012 | 08:37 PM
Grr's Avatar
Grr
thats false knock, turn down the knock sensors and put some timing in there. you will make the most power at 27*
Old Sep 11, 2012 | 08:41 PM
joecar's Avatar
He may be able to enable Lean Cruise (meaning he can retain CL).
Old Sep 11, 2012 | 08:45 PM
Rhino79's Avatar
Do you have the burst knock 0'd out? I couldn't make my car knock on 36* on e85.
Old Sep 11, 2012 | 09:03 PM
gpr's Avatar
gpr
I don't know why but everytime i go enter my engine displacement it never saves it, and i have to enter it several times before it applies. Speaking of that if i put in a bigger engine like 408, do i use the old 5.7L when doing calc.vet enter 6.1L?
Grr, I take it you mean 27 degree's at WOT. what about at cruising speeds what is best spark advance to maximize fuel mileage with e85?
thanks for the help i appreciate it.
Old Sep 11, 2012 | 09:51 PM
joecar's Avatar
You save the displacement in the log file after a log is captured.
You would enter 6688 cc (408 ci = 6.688L), you need to use the correct displacement with calc.vet...
or, if you're want to get comfy with g*K/kPa rather than % units (both in scantool and tunetool), then you never need to bother with entering displacement again.
Old Sep 12, 2012 | 12:17 AM
salemetro's Avatar
From what I've been told, even with it "enabled" in the tune, the PCM will still not allow any leaner than 14.7:1.....something to do with it being hard-coded in the PCM.....again, this is just what I've been told. Now, I suppose it's possible that it could work with E85, being that stoich is numerically so much "richer" than E0, but I'm not sure. Maybe someone else will chime in here?
Old Sep 12, 2012 | 12:58 AM
gpr's Avatar
gpr
My tune does already have the lean cruise tables in them. I need to enable it and see if it will actually do anything.
I was reading up on it and in efilive you need some .cax file and i put it where it says, but it is the only .cax file in the directory so not real sure if its gonna work or not. The lean cruise tables were there before i even read about this moving these files to enable it.
Old Sep 12, 2012 | 10:44 AM
joecar's Avatar
gpr, yes, you need the .cax file matching your OS (12212156), you enable LC, you populate the LC tables, and then you full flash.
Old Sep 12, 2012 | 10:50 AM
  #32
joecar's Avatar
We able to enable and run LC.
E85's stoichiometric AFR is "numerically richer" than E00, but in terms of Lambda it is the same (stoich = Lambda 1.0000)...
so for example, if he runs E00 or E85 (or anything in between), when LC enables he will see Lambda be about 1.035 (regardless of fuel).
Old Sep 12, 2012 | 10:52 AM
  #33
joecar's Avatar
Re-iterating from earlier: regardless of anything else, the stoich AFR in the tune needs to match the fuel being run (see parameter B3601 in EFILive).
Old Sep 12, 2012 | 10:57 AM
  #34
gpr's Avatar
gpr
Joecar, any advice on what to set B3638 the lean out rate. Also an initial lean cruise table values and coolant modifier. Never messed with it before or seen anyone set this up so not sure how lean to run it at what rpms. I'm thinking only lean it out at rpms i cruise down the highway at? Thanks for all your help!
Old Sep 12, 2012 | 02:01 PM
  #35
joecar's Avatar
I would have to browse some threads on the EFILive forum of people running LC...
Old Sep 12, 2012 | 02:07 PM
  #36
joecar's Avatar
I'm not sure if i can simply cut a portion of the log and save just that portion, this way i don't have to put a 20 minute log as an attachment???
BTW: ( I meant to answer this earlier )
you can highlight a section of the log, click the Crop button, and save the log as a new filename...
(hover over the buttons along the bottom of the scantool chart display).
Old Sep 12, 2012 | 04:18 PM
  #37
joecar's Avatar
Goto www.tunefiledepot.com and look at the 2001/2002 Holden tune files (EFILive format)... look at all the LC tables B3634-B3639.
The LC enable parameter is B9100, unzip and drop the attached .cax file into C:\Program Files\EFILive\V7.5\Calibrations
[ that .cax file is for 12212156/0202000x only and has the wrong addresses for any other OS ]
File Type: zip
Old Sep 14, 2012 | 10:55 AM
  #38
gpr's Avatar
gpr
Was going through my tune and making a few more adjustments. Why would someone disable burst knock? Seems like a good safety feature, unless I'm miss understanding what it does.
Old Sep 14, 2012 | 11:35 AM
  #39
BLK02WS6's Avatar
There's your KR...
Old Sep 14, 2012 | 02:03 PM
  #40
MontecarloDrag's Avatar
Sometimes when I disable Burst knock, I get knock retard on the logs. I reenable it and the knock retard is gone with no other changes.
Don't know why, but it makes the PCM pull timing because of false knock. Not always tho
