Are front 02 sensors needed on SD tune?
Old Sep 20, 2012 | 10:39 AM
Vcious04's Avatar
Default Are front 02 sensors needed on SD tune?
I know its probably a stupid question but I am at my last stages of fabing everything up and it's not the easiest to remove to add stuff. I will be tuning myself with HPTuners.
Simple question (I searched), are front 02's needed when going SD tune?
Old Sep 20, 2012 | 10:58 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Speed density, in and of itself, simply means there is no Mass Air Flow sensor in the equation, but a closed loop SD tune will still use the front O2 sensors. You can tune it OPEN LOOP speed density and not run front O2 sensors as well.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 20, 2012 | 12:59 PM
Strokinit383's Avatar
^^^BINGO. If you dont want to add the O2's, just run in open loop.
Old Sep 20, 2012 | 01:02 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
not needed, but i prefer to run them...
Old Sep 20, 2012 | 09:04 PM
joecar's Avatar
Trimming (LTFT and STFT) uses the front O2 sensors.
You can run SD with trimming (CL/LTFT/STFT or CL/STFT or OL/STFT see below) or without trimming (OL).
But when tuning you want to disable trimming (LTFT and STFT).
When you tune in OL, watch out that STFT are also disabled (otherwise you will get STFT trimming on any stoich cells in the OLFA table), this is sometimes overlooked.
