help with PCM for a 2006 impala ss
A 03-06 truck PCM (P59) will work but you also need the harness from same vehicle.
I think the easiest solution is to buy a E40 PCM with matched T42 TCM, unless you can buy a custom harness and a 03-06 truck PCM (or make one yourself)
