OBD-II Diagnostic Trouble Codes - DTC's
DTC B0024 LF/Driver Frontal Deployment Loop Shorted to Ground airbag lite onI measured the airbag under dash green wire, bag unplugged is 2000 ohms to ground, traced to the airbag module pin 3 is 2000 ohms to the case when removed from vehicle a used replacement module reads the same 2000 ohms to the case is it defective? Pin 3 is 3rd from the left when facing the module. If a tech with a good module and a Fliuke DVM could measure resistance from pin 3 to the case it would be a big help. Thanks in advance, bill122b
