Maf tuning question
Old Oct 23, 2012 | 09:18 AM
SStressin's Avatar
Default Maf tuning question
Ok so i did my ve table from 0-4000 rpm now im very confused how to tune the maf from 4000-7000. Cant find a good right up. I tried doing the histogram with afr error like it says online but wen i go to configure it it wont let me. Any good write ups on how to do from 4000-7000
Old Oct 23, 2012 | 10:38 AM
outkast6991's Avatar
You should be doing the entire VE table with the Maf failed. Then do the entire Maf table. Both should be tuned independently for the entire rpm range the motor will see. This way if the Maf fails the car will still run correctly
Old Oct 23, 2012 | 12:08 PM
SStressin's Avatar
Okay. Any write up for maf? Im very confused bout it from the stuff i see online
Old Oct 23, 2012 | 01:35 PM
I'm using efi live so I doubt I can help you much
Old Oct 23, 2012 | 02:56 PM
jimmyblue's Avatar
Moderator
Let's start with why you believe the MAF is wrong enough
to need calibration, when (Delphi at least) are factory set
up and reasonably accurate.
It's my opinion that if you aren't getting right fueling and
the MAF is as-stock, your error(s) probably lie elsewhere.
Old Oct 23, 2012 | 03:05 PM
Slowhawk's Avatar
LS1Tech Sponsor
As said, you have to tune the whole VE table. Then put the maf back in. I've seen stock maf's off as much as 40% when some work is done to the cars .Most are close within 10%
Old Oct 24, 2012 | 05:15 PM
SStressin's Avatar
i have a 85mm maf..
but i have seen everywhere online that they tune the ve up to 4000 then hook up maf back up and continue tuning the ve using maf calculations above 4000 is this correct?
