Tired of Security Light
Old Nov 10, 2012 | 09:27 AM
moeZ28's Avatar
Default Tired of Security Light
My security light stays on, all the time. When I bought the car, the previous owner had installed an aftermarket cd player, a sub, and new speakers, plus two little tweeters on the A-pillars. I took all that junk out except the new stock location speakers and the tweeters and put the stock cd player back in and got rid of the big damn box where the ttops go in the back. But my security light stays on constantly. my car starts, runs fine everytime but that damn light stays on! How do I get the damn thing to turn off??
Old Nov 10, 2012 | 01:46 PM
flame's Avatar
Find out what code is set and fix it or kill the bulb!!
Old Nov 11, 2012 | 08:01 AM
moeZ28's Avatar
Can a typical obd2 handheld scanner read this code, or do I need to get my tuner to pull it up with hptuners?
Old Nov 11, 2012 | 08:53 AM
99'CajunFirehawk157's Avatar
Your stock security sys has a few different settings, I think the prev poster was referring to that, look in your owners manual for more info on how to set it.
Old Nov 11, 2012 | 11:28 AM
moeZ28's Avatar
Ok...thanks!
Old Nov 11, 2012 | 06:16 PM
flame's Avatar
You will need something that can scan the body computer
Old Nov 12, 2012 | 07:26 PM
moeZ28's Avatar
According to the owners manual, the only reason the Security light on the gauge cluster stays on constantly even if the car starts and runs fine, is b/c of the stupid Passkey II system. Guess that means my resister chip is junk.
Old Nov 12, 2012 | 07:40 PM
flame's Avatar
If you turn the key on and the bcm doesn't see the proper resistance value from the key then the car will not crank and the pcm will not receive the fuel enable signal. Chances are someone has already tuned the vats out in the pcm and rewired the starter relay. Which will leave the light on!
Old Nov 12, 2012 | 07:43 PM
moeZ28's Avatar
i bought the car in December of last year...bone stock...and its never been flashed or tuned...until I had it done. I know the two previous owners.
Old Nov 13, 2012 | 12:01 PM
flame's Avatar
Then get the bcm scanned and get the security code. I'm telling you that if your key or cyl is toast the car will not start.
Old Nov 13, 2012 | 05:44 PM
moeZ28's Avatar
Ok. Is there no way the audio shop that put the stupid stereo system in the car messed up a wire in the dash or anything? I took that stuff out and put the stock cd player back in, but they had a sub and rca jacks, and a usb port added in the wiring...a bunch of crap i didnt want.
Old Nov 13, 2012 | 05:46 PM
moeZ28's Avatar
The codes in the manual have nothing to do with the security light...that is to program the headlights, map lights, signal flashers, etc. I am not talking about the blinking red light on top of the dash. I am talking about the security light on the gauge cluster.
Old Nov 14, 2012 | 07:06 PM
flame's Avatar
No **** thats what I've been talking about the whole time. GET THE BCM SCANNED FOR SECURITY CODES. NO ONE CAN HELP YOU FIX IT IF WE DON'T KNOW WHAT IS BROKEN
Old Nov 14, 2012 | 07:45 PM
Exclamation
My bad misunderstood, read dash light not cluster light.
Old Nov 14, 2012 | 08:46 PM
Tall Guy's Avatar
Of all the vats problems I have fixed over the years, 90% of the were cut wires from the ignition key cylinder. Everytime one turns the key the little wires bend and wear and after a while the will break. Here is a picture of the wires i am talking about:
this is a newer version with better wires insulator but same basic set up. The old wires that break were usually orange and white instead of 'clear' wrapped. I bet one of these is cut. The car will usually start with a cut wire as long as battery power hasn't been disconnected and the last key used to start the car had the correct chip in it. The light flashes to tell you at that point there is obviously a problem. If battery power was lost then the car wont start. Unfortunatly you have to remove the steering wheel and S.I.R. coil to physically check the wires. Hope this helps some...
Old Nov 15, 2012 | 07:57 PM
moeZ28's Avatar
I have an aftermarket steering wheel and no airbag crap anymore...Have an air bad light on cluster as well...but the security light was on before i did all that so i know that wasnt it. I have had the battery disconnected on a few occasions...the car always starts and runs fine. just has that security light on the cluster...it never blinks...just stays on solid.
Old Nov 15, 2012 | 07:58 PM
moeZ28's Avatar
I figure it is something to do with the key or ignition switch, if there is no way the stereo guys could have screwed up some wiring.
Old Dec 20, 2012 | 06:43 PM
daturbosix's Avatar
Restricted User
i got the same issue. my bet is on the lock cylinder wire being bad, i just havent pulled it to check yet.
i see you mentioned you dont have airbags anymore.. how did you get that light off?
Old Dec 26, 2012 | 12:25 PM
mk3cn4's Avatar
Wanted to mention the possibility that if he had a bunch of stereo crap in there he may also have had a remote starter, which means they may have tinkered with the passkey stuff with one of those passkey fakeout boxes or something and didn't wire it well.
