LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
Are you in San Diego now? I used to be stationed there. Most of the auto parts stores should carry them for pretty cheap. Autozone has one for $45. Good tool to have.
http://www.autozone.com/autozone/acc...ier=84174_0_0_
LS1TECH & Trucks Sponsor
check your fuses under the hood. It sounds like you killed one of the fuses with your messed up O2 wiring to me. I've seen it before, but I don't recall which fuse it should be.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I checked all the visibly inspectable fuses. I need to get a test light on the other ones. The only wires that are jacked up are the ones connected to the sensors. The extensions fell off.
Wow no kidding. There is nothing around you. Maybe just order it from their website would be easier than the 3 some odd hours of driving.
As just a test can you prime the fuel system wait a few minutes and then press the shredder valve on your fuel rail? This should at least tell you if the system is holding pressure. Some thing to try in the mean time.
Any luck on getting the o2 hooked back up?
Funny I had a bad fuel pump in my Z28 and it made the car cam out hard. Fuel would not hold at the rail and would lose fuel pressure, also had burned wires to connecter harness. I would check these things out. A marginal fuel pump will still provide an okay amount of fuel to keep the car running. but I would not run it hard. It will lean out.
No EGR on this car, that why I got the code. It's not tuned out though. Literally, isn't even on the car, no chance.
#32
Well that's opposite of what this car is doing. I will NOT idle, for even 1 second. I have to pump the gas to keep it running. It runs normal WOT. It's noticeably running very rich.
#33
#34
you dont have an autozone or napa? cause the oxygen sensor for the vette is bosch 13111 you keep throwing money at electrical parts you will go broke, fix the obvious things that you have found first ,You said that your oxygen sensor wiring was junk i wouldnt have went any further than that.My car wouldnt run when my extension harness burned.Only wot,I have owned my car since it was new in 2000 so i am not an expert but i do have a been there done that experience.
#35
#37
Yes... It is running worse now. It started missing pretty bad and backfiring really bad. I switched out the MAP Sensor on it since I had a code for it. It didn't change a thing. The o2's are on their way, should be here this weekend. I unfortunately am putting all my marbles on these o2 sensors. If it has been run like this for so long, I heard the fuel trims could be messed up. How do I reset these for sure? I just don't understand how o2 sensors could have this much effect on how it runs. Can you post a video to here? I know you guys havent heard an LS1 run like this.
#38
I've had O2 sensors cause some serious issues. I always disconnect the battery and hold the + and - together for a while. I heard this drains any capacitors that may have juice. When you reconnect everything it should relearn everything that is dynamic. I've done this after replacing my O2 to make sure they are using the new accurate inputs.
As far as a video. It is easiest to upload to Youtube and link it.
#39
#40
From my understanding the only time o2 sensors are used is on idle and light loads. After that it is all the programmed maps. Granted they are constinantly being monitored for Cat malfunctions. This wiki has some good info.
http://en.wikipedia.org/wiki/Oxygen_sensor
