The salvage yard ripped me off..
Old Dec 27, 2012 | 07:38 PM
inda_bebe's Avatar
Default The salvage yard ripped me off..
I got a motor delivered from the salvage yard. They said it was from an '04 suburban 5.3l. It came with a harness and PCM. But, it was throttle cable, blue and red connectors and a 411 PCM. Anyone know if I can find a vin on the block and ID it? I would know what to request for when I flash and tune this thing. Also, can I use a '02 harness with an '04 block?
Old Dec 27, 2012 | 08:23 PM
Old Geezer's Avatar
Rear/dr side of the block..Should be laser etched near the trans mt face.
Old Dec 27, 2012 | 09:15 PM
inda_bebe's Avatar
I found the it (c2g197698) but how do I find the year of of it?
Old Dec 27, 2012 | 09:43 PM
1-87 chevy's Avatar
the motor will be the same and interchange thru 06
Old Dec 30, 2012 | 10:39 PM
inda_bebe's Avatar
So what if the motor was an '04 and the harness was the red and blue. Should I follow the pin removal off of the '02 harness?
Old Dec 31, 2012 | 02:56 PM
James@ShorTuning's Avatar
The pinouts area going to be very similar. There is a few sensor changes over the years but the main components such as injectors, coils, MAF, MAP, TPS, Crank, Cam etc are all going to be located in the same pin location. The only real difference on the red/blue connector PCM's is whether its DBW or cable TBw/ IACV.
The main components on the engine itself didn't change any from 99 to 06 besides oil pressure and type of throttle body and possibly injector clips from various different models.
Old Jan 10, 2013 | 11:57 AM
wait4me's Avatar
Your motor is a 2002 from the looks of it. Going off of your tag you supplied, im going to guess that the full vin was 3GNFK16ZX2G197698
Old Jan 11, 2013 | 07:31 AM
Old Geezer's Avatar
Sounds to me as tho a call to the jy is in order. If it's an 02, they owe you the correct engine and accessories...
