4L80E Input Torque
Old Jan 30, 2013 | 09:04 PM
LongIsland63SS409's Avatar
Default 4L80E Input Torque
Originally posted in the automatic transmission section but got no responses there.
I downloaded the stock ECM program using HP Tuners the other day using a bench harness.
The trans is a stock 4L80E. Going thru the different tabs I came across the torque input.
It is factory rated at 610 ft/lb in stock form.
New to HP Tuners and wanted to share this info.
Am I reading this correctly?
Mike
Old Jan 31, 2013 | 10:12 AM
wait4me's Avatar
What exactly are you wanting to know? To answer your exact question, Yes.
Old Jan 31, 2013 | 08:01 PM
I guess I answered my own question.
Thank you for confirming that is what the table means.
The screen shot is the first time I used HP Tuners.
Mike
Old Feb 1, 2013 | 10:25 AM
wait4me's Avatar
It is just a limit, it isn't like you are going to hit it with a stock engine, so mostly changing those things that have super high limits already will not make a change.
You can always make a small change to things and see if you can see or feel a difference. If no change, then you can go back to stock settings in a quick flash.
Old Feb 3, 2013 | 07:05 AM
Thank you for answering my question on the torque input.
Mike
