RPM/Engine will Not Respond to Pedal, CAM Tune E38 HELP!!!!!!!!
HI, truck idles fine and drives well but when you Press the Gas 100% WOT it Does Not Respond rpms very Slowly Merge to 2800-3K rpm and it just doesnt accelerate on Both P/N/Gear rpms will not go up in accordance to throttle position, im thinking its a ETC table or something but just dont know id like if you guys could Helpor give me tips on what table to mess with, I will upload Tune & Log 2morrow anything i should Log in Specific?
HP Tuners Tune File Attached....
http://www.hptuners.com/forum/showthread.php?t=42112
Vehicle Info: 2010 Silvy, Originally a 5.3 Swapped for a LY6 6.0L, 243Heads, DOD Delete, 232/236 .595"/.598" 112+2 LSA , 3600 Single disc Stall, 4.11s, LTs, CAI
Please Help!
Thanks!
Please Help!
Thanks!
For you guys having issues with this probles "3K rpm LAG and no gain after that" it was a timing issues, VVT crap was removed and PCM saw error therfore thre a CAM sensor code indicating (after goi g over tune thrully and emberassed to say) Damn DOD/VVT crap was enabled on Tune, hope this helps some1 down the line with this simple but honest mistake
