99+ pcm swap tachometer issue
I have a 99+ LS1 PCM and engine harness in my 98 body with 98 body harness.
I have almost all of the guages working except the tachometer. I know the tach has a feed on #10 coming out of the PCM and on one of the shock tower plugs for the traction control. If I tap into either one of these wires and run a new wire to my dash harness will this give the appropriate signal to run the tachometer on a 98 dash? Ive read on here where people run their aftermarket tachs off of these wires but wanted some more information before I go splicing and running wires aimlessly.
THANKS
The G C105 would be a great spot for those of you wanting to run aftermarket tachometers to tap into the harness especially if you dont have traction control or deleted it. it is much easier to access and wire tuck the new wire than the wire going into the PCM or other spots on the engine harness.
Also, I'm not sure which plug your speaking of when referring to C105.
