LS1 edit or Snap On MT2500 or...
Old Apr 19, 2004 | 10:27 PM
ButchN's Avatar
Default LS1 edit or Snap On MT2500 or...
With all the talk about Tech II & LS1 edit, should I take it that with my '00 TA that my old reliable Snap On MT2500 is not a good tool to do tuning, a case learn, or anything to my car?
Since I got the car I was going to get updated cartridges (ebay of course!) since my current cartridges only are until 98.
Should I not invest in a set of cartridges or should I sell my MT2500 & get another diagnostic scan/tuning tool, namely LS1 edit?
I still have the wife's 96 Sebring vert to plug into when needed.
Thanks
Old Apr 20, 2004 | 12:57 AM
68LSS1's Avatar
I also have a Snap-On scanner and think it is a very good scan tool. As you know everything the computer sees, you see. Haven't used it much on LS1's but you still will need Edit. I need to see if it's capable of doing things like the crank sensor relearn procedure (I've got the code cartridge to '00 but the t/s to '97 or '98).
Old Apr 20, 2004 | 07:00 AM
cablebandit's Avatar
can it reprogram the vin in the instrument cluster..airbag sensor or pcm? I need to have this done and can't do it with edit....to get my airbag light off after changin all three items
Old Apr 20, 2004 | 10:00 AM
68LSS1's Avatar
No the Snap-On unit cannot. That will require dealer (GM) type equipment.
