wideband o2 sensor help!!
Old Mar 6, 2013 | 02:52 PM
V666's Avatar
Default wideband o2 sensor help!!
Is it possible to wire two wide band o2's to a switch and toggle between them?
Old Mar 6, 2013 | 03:03 PM
jimmyblue's Avatar
Moderator
If you mean the sensor itself, that's a bad idea. The
one that is not heated, will foul out real quick. That
is also a problem with long-term-installed ones, esp.
if you forget to preheat before starting, a lot. I had
killed my first LM-1 sensor this way, leaving it in the
pipe and not turning on the meter every time.
Two complete lineups and switching which output
the scan tool sees, both of them kept hot and active,
ought to be OK (just a waste of money most of the
time).
Old Mar 6, 2013 | 03:24 PM
wait4me's Avatar
Yes it is possible. However as Jimmy says, you want to make sure the HEATER circuit is being turned on, on both of the sensors always. If the customer here wants something like that, I just wire up the signal wires to the switch, but jumper over the heaters on both of them thru the controller. It works just fine.
Old Mar 8, 2013 | 11:18 PM
MikeyZ's Avatar
if you have hptuners why not use them both at the same time to scan using the egr and pressure sensor 5V wiring
