Holley EFI use with stock gauges
Old Mar 13, 2013 | 07:36 PM
Br1_ss's Avatar
Default Holley EFI use with stock gauges
has anyone installed the Holley EFI to their setup and keeping the stock gauges?
I noticed today when i was installing the kit that the harness doesn't have the connector for the blue and white plug that is underneath the dash on the passenger side.
Also how did you guys install the harness?
I was planning on doing the wire tuck mod but I guess plans will be changing.
My car is a 2002 Camaro with a 6speed. from what it looks like the harness doesn't connect to the transmission either.
If you have Holley HP EFI give me some feedback!!!
Old Mar 13, 2013 | 08:16 PM
Br1_ss's Avatar
anyone run into this issue?
Old Mar 14, 2013 | 06:42 AM
LS1PUNK's Avatar
Stock gauges will not work with the ECU.
As far as the trans, I think the only ones it can control is 4l60 and 4l80.
Old Mar 14, 2013 | 06:58 AM
Br1_ss's Avatar
so it's either using the Holley touchscreen or run a bunch of gauges??
I don't need to plug any in the t56?
Old Mar 15, 2013 | 06:27 PM
Moore Racecraft's Avatar
Correct it wasn't designed to run stock gauges. The ECU doesn't need VSS for any control therefore the T56 doesn't need to be connected.
Old Mar 16, 2013 | 03:22 PM
Br1_ss's Avatar
What would be the best way to run power to the headlights and the rest of the stuff that connected to the BCM??
This car is going to be driven on the street not just track
Old Mar 22, 2013 | 09:57 AM
speedracer5532's Avatar
Couldn't you also keep the stock ecu in the car to run the stock gauges?
Old Mar 22, 2013 | 10:15 AM
mike13's Avatar
Some people have piggybacked the BS3 ecu with the stock ecu to run their gages.
Old Mar 22, 2013 | 10:35 AM
MustangLS's Avatar
If you go with Holley gauges they all use the same signal wire from the HP. You program each one.
Old Mar 24, 2013 | 02:20 AM
same o'j's Avatar
i interested to know , and how can the T-56 will get lock after car start move ??!!!
Old Jul 23, 2013 | 09:58 AM
fastsspr's Avatar
Anyone have piggybacked a Holley efi to the stock ecu?
Old Jul 25, 2013 | 12:36 PM
Berz28's Avatar
Default Piggyback stock pcm
I'm very interested to know how this is done also. i'm using a different standalone but wout also like to keep the factory gauges.
Old Mar 4, 2014 | 05:34 PM
Br1_ss's Avatar
thread bump! I sold my Holley HP but I'm thinking about getting another one and getting rid of the stock gauges and running the touch screen gauge. Anyone running this ECU with a 4th gen car yet? If so, did you make a build thread???
Old Mar 4, 2014 | 05:47 PM
ls1CANTU's Avatar
I'm about to do the Holley ECU and going to wire it to keep stock gauges. Will let y'all know soon how it goes
Old Mar 7, 2014 | 11:37 AM
shawnc16's Avatar
Over on the bullet, a couple guys are using tablets.
http://www.yellowbullet.com/forum/sh...d.php?t=559816
Old Mar 17, 2014 | 03:38 AM
Br1_ss's Avatar
this is pretty badass!!! maybe we can get the tablet to fit and it'll look like the model S touchscreen
Old Mar 20, 2014 | 08:16 PM
rpturbo's Avatar
I just attended a tuning class at Holley, and you can run some factory gauges. Don't ask me how, I can't remember, but it just has to do with correctly setting up the outputs. If you call tech and talk to one of the guys, I am sure they can explain it. That Dominator can do just about anything. The HP is restricted by no trans controller, and less I/O's.
Old Mar 21, 2014 | 05:15 AM
Exidous's Avatar
Aye, just because the harness doesn't have the wires doesn't mean you cannot do it. You are ultimately limited by the # of outputs on the HP. You cuold probably even wire the VSS into the Holley and have it output to the speedo for you.
Old Mar 25, 2014 | 06:22 PM
rpturbo's Avatar
Yep I agree, it's just not going to be 100% plug and play, but it can run factory gauges with a little work.
Old Apr 11, 2014 | 08:09 AM
Br1_ss's Avatar
Pulling the trigger next
Week and purchasing the dominator.
No I'm not running the stock gauge haha
